C2G 3m Cat5E 350 MHz Snagless Patch Cable - White
Quicklinx: 6BN1WS00 Mfr#: 83264
Length: 3m
Colour: White
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring a reliable connection and long-lasting performance. Its gold-plated RJ-45 connectors provide optimal signal clarity and shielding against interference, making it a suitable choice for high-speed network applications.
  • Enhanced performance
    Tested to support frequencies up to 350 MHz, this patch cable meets the performance requirements of Category 5e. It's equipped with T568B wiring and eight wires per cable, facilitating high-quality data transmission and reducing system noise and interference for improved network reliability.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 3m
Colour: White
Brand: C2G
