The USB-C to A 3.0 Male to Male Cable is the perfect solution for connecting any standard USB-C enabled device, such as a Chromebook, laptop, tablet or smartphone, to a USB-A device, accessory or peripheral up to 10ft away for fast charging and high-speed data transfer. Whether you're desk-based or on-the-road, this one-cable solution ensures that your USB-C equipped device is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music, or data at speeds up to 5 Gbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
Efficient data transfer
Experience swift data transfer with the 5 Gbps data rate of this USB C cable, ensuring quick syncing and charging for your devices. -
Versatile compatibility
Designed with a 24-pin USB-C and a 9-pin USB-A connector, this cable supports a wide range of devices, making it a versatile addition to your tech toolkit. -
Durable design
The nickel-plated connectors not only provide a reliable connection but also resist corrosion, ensuring long-term durability and performance.
- C2G 3m (10ft) USB C Cable - USB A 3.0 (3A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to USB Type A - 3 m
- USB-C cable
- Sync and charge, 5 Gbps data rate
- Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - male
- Rated Current
- 3 A
- USB / USB 2.0 / USB 3.0
- Black
- 3-year warranty
- USB-C cable
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, USB-IF, UL 2725, RoHS 2 (2011/65/EU)
- 3-year warranty
