C2G 3ft (0.9m) Cat6a Snagless Unshielded (UTP) Slim Patch Cable - Orange
Quicklinx: HGXGWS00 Mfr#: C2G30175
£3.73 ex VAT
£4.47 inc VAT
The Cat6a Snagless Unshielded (UTP) Slim Network Patch Cable is the perfect solution for high density cabling applications such as large conference rooms and datacenters. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colors to easily color-code your network installation.
This network cable supports ethernet speeds up to 10Gbps at distances up to 328ft which is ideal for large conference rooms that may be leveraging HDBaseT technology. Cat6a technology doubles the minimum bandwidth of previous Cat6 cables and is five times more powerful than Cat5e. This increase in data speeds and bandwidth makes it the perfect Power over Ethernet (PoE) and Voice over Internet Protocol (VoIP) situations.
The use of 28AWG conductors allows for greater flexibility in those tight space installations where space is always crucial. This reduced diameter provides a smaller cable surface area which allows for increased airflow when compared to standard Cat6 cables. And lastly, these cables are backed by a lifetime warranty to provide peace of mind.
  • Colour
    Orange
  • Warranty
    Lifetime
  • Connector 1:
    (1) RJ-45 Male
  • Connector 2:
    (1) RJ-45 Male
C2G 3ft (0.9m) Cat6a Snagless Unshielded (UTP) Slim Ethernet Network Patch Cable - Orange - patch cable - 90 cm - orange
Patch cable - CAT 6a
Unshielded twisted pair (UTP)
Shielding Material
Aluminum foil wrap
Wires per Cable
8 wires
Snagless, molded, Slim, strain relief, up to 10 Gbps, Power over Ethernet (PoE), Voice over Internet Protocol (VoIP), 300V DC insulation resistance, 100% test for short/open: 10M O
Length
90 cm
Diameter
4.8 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Package Type
Polybag
Network Cable Type
Shielding Material
Aluminum foil wrap
Jacket Material
PVC
American Wire Gauge (AWG)
28
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
90 cm
Diameter
4.8 mm
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS 2 (2011/65/EU), ANSI/TIA 568.2-D, ISO/IEC 11801-1
Package Details
Polybag
Brand: C2G
