With LC to LC termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
High compatibility
Designed to seamlessly integrate with PC systems, this LC-LC 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable ensures a reliable connection for all your networking needs. -
Durable construction
Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable is built for both safety and durability, minimizing toxic emissions in the event of a fire and ensuring a long-lasting performance. -
Optimal performance
With a core and cladding diameter of 62.5 / 125 micron, this cable is engineered for superior signal transmission, supporting a wide range of multimode fiber optic applications.
- C2G LC-LC 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable (LSZH) - patch cable - 30 m - orange
- Patch cable - OM1
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free
- Length
- 30 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Orange
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OM1
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 62.5 / 125 micron
- Halogen-free
- Length
- 30 m
- Orange
- Connector
- TIA/EIA-455-171A
- -20 °C
- 70 °C
