All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
Enhanced connectivity
Experience seamless and reliable connectivity with the C2G serial/parallel cable, designed to link your devices with ease. Its dual functionality supports both serial and parallel interfaces, making it a versatile choice for connecting a wide range of peripherals. -
Durable design
Constructed with shielded technology, this cable ensures superior signal integrity and reduces electromagnetic interference. The robust build quality ensures a long-lasting connection between devices, enhancing your workflow without compromise. -
Universal compatibility
Designed to meet the needs of PC users, the cable features a 25 pin D-Sub (DB-25) male connector on both ends, offering broad compatibility with various devices. This ensures a reliable connection to printers, scanners, and other essential peripherals.
- C2G - serial / parallel cable - DB-25 to DB-25 - 30 m
- Serial / parallel cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 30 m
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- Technology
- Shielded
- Length
- 30 m
- Connector
- RoHS
