This power cord is the ideal solution for powering a network device or connecting to a PDU in a data centre or network wiring closet. This cable is able to support up to 250 volt connections and features 1.00mm² conductor construction. The fully moulded design provides for maximum durability and long life.
Robust compatibility
Designed to meet the needs of PC users, this power cable ensures seamless connectivity and power supply to your computing devices. -
High safety standards
Adheres to Directive 2011/65/EU and RoHS compliant standards, ensuring a safe and environmentally friendly power solution for your devices.
- C2G - power cable - IEC 60320 C15 to BS 1363 - 2 m
- Power cable
- Length
- 2 m
- Localisation
- United Kingdom
- Connector
- Power IEC 60320 C15
- Connector (Second End)
- Power BS 1363 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- Rated Voltage
- AC 250 V
- Length
- 2 m
- Black
- Localisation
- United Kingdom
- Connector
- RoHS, Directive 2011/65/EU
