C2G 2m Mini DisplayPort Cable M/M - White
Quicklinx: 9MSDWS00 Mfr#: 84411
Length: 2m
Select:
£12.25 ex VAT
£14.70 inc VAT
This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • Resolution Support
    Supports up to 4K resolution
  • DisplayPort Specification
    DisplayPort 1.2 Standards
  • Cable Colour
    White
C2G 2m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 2 m
DisplayPort cable
Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
White
DisplayPort cable
Length
2 m
White
Connector
DisplayPort 1.2
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
