C2G 3m Mini DisplayPort Cable M/M – White
Quicklinx: 9MSFWS00 Mfr#: 84412
Select:
  • 3m
This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • Seamless connectivity
    Experience high-quality, uninterrupted connections with the 3m Mini DisplayPort Cable 4K UHD M/M - White, designed to link your devices with ease. Its compatibility with DisplayPort 1.2 standards ensures you can enjoy 4K video content at ultra-high definition without any compromise.
  • Durable design
    Crafted for both durability and performance, this cable features robust male connectors on both ends, ensuring a secure and stable connection between your devices. The white cable not only adds a sleek look to your setup but also promises longevity for extensive use.
C2G 3m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
White
DisplayPort cable
Length
3 m
White
Connector
DisplayPort 1.2
