This OM4 Duplex Multimode fibre optic cable is ideal for connecting 40GBase-SR4 and 100GBase-SR10, SFP+ and QSFP+ transceivers for 40 and 100 gigabit network connections. This cable provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 40 or 100 gigabit Ethernet applications in a data centre or wiring closet.
Enhanced connectivity
The 2 m LC/SC OM4 LSZH Fibre Patch Cable ensures superior connection quality and reliability for high-speed data transmission, featuring duplex multimode fiber optic technology. -
High-quality construction
Constructed with a 50 / 125 micron core and cladding diameter and encased in a Low Smoke Zero Halogen (LSZH) jacket, this patch cable is designed for both safety and performance. -
Versatile compatibility
Equipped with LC multimode male connectors on one end and SC multimode male connectors on the other, this cable offers flexible connectivity options between various network devices.
- C2G 2m LC/SC OM4 LSZH Fibre Patch - Purple - patch cable - 2 m - purple
- Patch cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- 2 x SC multi-mode - male
- Purple
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OM4
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 2 m
- 50 g
- Purple
- Connector
