C2G 2m IEEE-1284 DB25 M/M Parallel Cable
Quicklinx: 684PWS00 Mfr#: 81472
High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two-way communications offered by your printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
C2G parallel cable - 2 m
Parallel cable
Double shielded twisted pair
Molded
Length
2 m
Connector
DB-25 - male
Connector (Second End)
DB-25 - male
RoHS
Parallel cable
Shielding Material
Foil with braid
Molded
Length
2 m
Connector
25 pin D-Sub (DB-25) - male
IEEE-1284, RoHS
