C2G 2m EU-CEE 7/7 to C15 Power Cord
Quicklinx: D0C7WS00 Mfr#: 80638
This power cord is the ideal solution for powering a network device or connecting to a PDU in a data centre or network wiring closet. This cable is able to support up to 250 volt connections and features 1.00mm² conductor construction. The fully moulded design provides for maximum durability and long life.
  • Robust compatibility
    Designed specifically for PCs, this power cord seamlessly integrates with a wide range of computer systems, ensuring a reliable connection and power supply.
  • Durable design
    Featuring a robust cable with a male CEE 7/7 to IEC 60320 C15 connection, this power extension cable is built to withstand AC 250 V, making it ideal for a variety of demanding applications.
C2G 250 Volt Hot Condition European Power Cord - power extension cable - power CEE 7/7 to IEC 60320 C15 - 2 m
Power extension cable
Molded
Length
2 m
Europe
Connector
Power CEE 7/7 - male
Connector (Second End)
Power IEC 60320 C15
Rated Voltage
AC 250 V
Rated Voltage
AC 250 V
Molded
Length
2 m
Europe
Connector
Power IEC 60320 C15
