C2G 2m Cat6 550 MHz Snagless Patch Cable - Yellow
Quicklinx: 6BR8WS00 Mfr#: 83468
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support frequencies up to 550 MHz. This high-quality cable ensures fast and reliable connections for all your networking needs.
  • Durable design
    Constructed with a PVC jacket and 24 AWG wire, this patch cable is built for durability. The gold-plated RJ-45 connectors provide optimal signal clarity and shielding against interference, ensuring long-lasting, high-quality connections.
  • Universal compatibility
    With T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for a wide range of networking requirements. Its universal design ensures it can be easily integrated into existing network setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - yellow
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
2 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
