For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures efficient data transfer and high-speed connectivity for all your computing needs. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket material, this patch cable is built for durability. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring a long-lasting, high-quality connection. -
Universal compatibility
Featuring a T568B wiring scheme and RJ-45 connectors, this network patch cable is compatible with a wide range of devices. Whether you're connecting PCs or other network devices, setup is straightforward and hassle-free.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - orange
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Orange
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 2 m
- Orange
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
