C2G 2m Cat6 550 MHz Snagless Patch Cable - Green
Quicklinx: 6BQKWS00 Mfr#: 83428
Length: 2m
Colour: Green
£2.93 ex VAT
£3.51 inc VAT
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, offering tested frequencies up to 550 MHz for rapid data transfer and high-speed communications.
  • Durable design
    Constructed with a PVC jacket material and 24 American Wire Gauge (AWG), this patch cable is designed for durability and long-lasting performance, ensuring your network setup remains robust and reliable.
  • Enhanced connection quality
    Featuring gold-plated connectors and a T568B wiring scheme, this cable provides a high-quality, stable connection that minimizes interference, ensuring clear and uninterrupted data transmission.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
2 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 2m
Colour: Green
Brand: C2G
