For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, offering tested frequencies up to 550 MHz for rapid data transfer and high-speed communications. -
Durable design
Constructed with a PVC jacket material and 24 American Wire Gauge (AWG), this patch cable is designed for durability and long-lasting performance, ensuring your network setup remains robust and reliable. -
Enhanced connection quality
Featuring gold-plated connectors and a T568B wiring scheme, this cable provides a high-quality, stable connection that minimizes interference, ensuring clear and uninterrupted data transmission.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - green
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Green
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 2 m
- Green
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
