For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
                High-speed connectivityExperience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures efficient data transfer and high-speed connectivity for all your computing needs.
                Durable designConstructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring your network setup remains uninterrupted.
                Universal compatibilityWith its T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for connecting a wide range of devices. Whether for home or office use, it ensures a stable and secure connection every time.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - blue
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 2 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
