C2G 2m Cat5E 350 MHz Snagless Booted Patch Cable - Red
Quicklinx: 69NCWS00 Mfr#: 83223
Length: 2m
Colour: Red
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved network performance. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, making it an ideal choice for various networking requirements.
  • Durable design
    Featuring a robust PVC jacket, this network patch cable is built to withstand the rigors of daily use in busy office environments. The boot cover adds extra strain relief, protecting the most vulnerable part of the cable from bending and breaking.
  • High-speed data transmission
    With a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for applications requiring high-speed Internet, file sharing, and video streaming. Its unshielded twisted pair (UTP) technology minimizes noise and interference, ensuring clear signal transmission.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 2m
Colour: Red
Brand: C2G
