This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
Enhanced connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed to facilitate seamless data transfer and communication between PCs, ensuring a reliable connection with its high-quality construction. -
High-speed performance
With a tested frequency of up to 350 MHz, this cable supports fast data transmission speeds, making it ideal for various networking requirements and enhancing your productivity. -
Durable design
Featuring a PVC jacket material and gold-plated connectors, this crossover cable is built for durability and long-lasting performance, ensuring a secure connection with minimal interference.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 2 m - yellow
- Crossover cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 2 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 350 MHz
