C2G 2m Cat5E 350 MHz Crossover Patch Cable - Grey
Quicklinx: 6BNCWS00 Mfr#: 83283
This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
  • High-quality connectivity
    Featuring a high-grade PVC jacket and 24 AWG American Wire Gauge construction, this Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable ensures durable and reliable connectivity for all your networking needs. The gold-plated connectors provide a secure connection with minimal signal loss, making it suitable for a variety of PC compatibility scenarios.
  • Enhanced performance
    Designed to support a tested frequency of up to 350 MHz, this crossover cable facilitates high-speed data transmission and is optimized for fast and efficient networking. The T568B wiring scheme and UTP technology work together to reduce interference, ensuring clear and stable signal quality for your network.
  • Eco-friendly choice
    Compliant with RoHS standards, this network cable is manufactured with environmentally friendly practices. It's an excellent choice for users who are conscious about reducing their ecological footprint while maintaining high standards of network performance and reliability.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 2 m - grey
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
2 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
