C2G 2m 16AWG 250V 16 Amp Power Ext IEC 60320 C20-IEC 60320 C19
Quicklinx: 98PWWS00 Mfr#: 80623
Make your work environment more flexible and efficient. This heavy duty 16 AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
  • Product Use
    Extend the length of your power cord
  • Warranty Details
    This product carries a lifetime warranty
  • Connector Information
C2G 16 AWG 250 Volt 16 Amp Power Extension Cord - power extension cable - IEC 60320 C20 to IEC 60320 C19 - 2 m
Power extension cable
Molded
Length
2 m
Connector
Power IEC 60320 C20
Connector (Second End)
Power IEC 60320 C19
Rated Voltage
AC 250 V
American Wire Gauge (AWG)
16
Rated Voltage
AC 250 V
Molded
Length
2 m
Connector
Power IEC 60320 C20
Power IEC 60320 C19
