C2G 20m LC-LC 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
Quicklinx: 9CDWWS00 Mfr#: 85611
Length: 20m
Colour: Yellow
£34.40 ex VAT
£41.28 inc VAT
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With LC to LC termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this fiber optic cable is designed for environments where protection against smoke and toxic compounds is critical. Its durable construction ensures long-lasting performance and reliability.
  • High-quality connectivity
    With LC single-mode connectors on both ends and a duplex configuration, this cable provides high-quality, stable connections for telecommunications and data transfer. The 9 / 125 micron core and cladding diameter facilitate precise, efficient signal transmission.
  • Wide temperature range
    Engineered to withstand extreme conditions, this cable operates flawlessly in temperatures ranging from -20°C to 70°C. This versatility ensures reliable performance in various environmental conditions, making it suitable for a wide range of applications.
C2G LC-LC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 20 m - yellow
Patch cable - OS1
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free
Length
20 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x LC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Patch cable - OS1
Duplex fibre optic
Singlemode
Jacket Material
Fibre Qty
2
9 / 125 micron
Halogen-free
Length
20 m
Yellow
Connector
TIA/EIA-455-171A
-20 °C
70 °C
Length: 20m
Colour: Yellow
Brand: C2G
