For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and high-speed data transfer rates of up to 350 MHz. Its gold-plated RJ-45 connectors provide optimal signal clarity and minimal interference, making it an ideal choice for both home and office networks. -
Durable design
Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use. The boot cover for the RJ-45 connectors offers added strain relief, protecting the connection points from bending and breaking, which ensures a longer lifespan for your investment. -
Universal compatibility
With its T568B wiring scheme and UTP technology, this patch cable offers broad compatibility with PCs and network devices. Its unshielded design allows for use in a variety of networking environments, from simple home setups to more complex office networks.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 20 m - black
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 20 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 20 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
