C2G 2-Port USB Hub
C2G 2-Port USB Hub
Quicklinx: 8017WS00 Mfr#: 81651
This hub connects up to 2 USB 2.0 devices with just one cable. Two USB A female ports will receive your mice, printers, hubs, or other USB devices without them being cluttered together. Unlike traditional USB hubs, this cable can slide behind your desk and out of the way, or connect on the front of a desktop so you would not need to reach in the back of the PC. With its small form factor it eliminates the clutter associated with traditional hubs, and lets you spread out your devices. Bus-powered, so it requires no external power adapters. Compliant with USB 2.0 specifications; compatible with both PCs and Macs.
  • Warranty
    1 year
  • Colour
  • Length
    1ft
C2G 2-Port USB Hub - hub - 2 ports
Hub - 2 ports
Subtype
USB
Ports
2 x USB 2.0
USB powered
USB 1.1, USB 2.0
39 g
Apple MacOS X or later, Microsoft Windows 98SE/2000/ME/XP/Vista/7
1-year warranty
Hub - 2 ports
Enclosure Type
Desktop
Subtype
USB
Ports
2 x USB 2.0
USB powered
USB 1.1, USB 2.0
2 x USB 2.0 Type A , 1 x USB 2.0 Type A
1 x USB cable - 30 cm
Plug and Play
39 g
Limited warranty - 1 year
