TP LINK UH700 USB 3.0 7-Port Hub
Quicklinx: 9X9HWS00 Mfr#: UH700
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 7
Form Factor: External
15 In Stock
£23.08 ex VAT
£27.69 inc VAT
The UH700 USB Hub is a great choice to expand the USB ports of your computer for data transfer when you need to connect USB drives, USB mice, printers or other devices simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than USB 2.0.
High Speed Data Transfer
Equipped with USB 3.0 ports, UH700 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0.
Greatly Expand Your USB Ports
UH700 adds PC 7 additional USB ports to your PC, making it unnecessary to switch between devices.
Safe and Reliable
UH700's multiple protections avoid any potential harm to your connected devices no matter you're transferring data or charging devices.
  • High speed data transfer
    Equipped with USB 3.0 ports, UH700 provides a data transfer rate of up to 5Gbps, saving your time.
  • Greatly expand your USB ports
  • Safe and reliable
TP-Link UH700 - hub - 7 ports
Hub - 7 ports
Ports
7 x SuperSpeed USB 3.0
USB 2.0, USB 3.0
16.5 cm x 6.55 cm x 1.75 cm
Hub - 7 ports
Enclosure Type
Desktop
Ports
USB 2.0, USB 3.0
1 x VIA VL812
7 x USB 3.0 Type A , 1 x micro-USB 3.0 Type B
External power adapter
1 x USB cable - 1 m
16.5 cm
6.55 cm
1.75 cm
Type: USB Hub
Speed: 5Gbps
Ports: 7
Brand: TP LINK
