The USB A Male to Lightning Male sync and charging cable is perfect for downloading data from or uploading data to the latest generation of Apple iPad, iPhone or iPod devices while also allowing the device to be charged. The cable construction and design make it ideal for travel. This cable is great as a replacement or a spare to sync and charge an Apple device at home, in the office or on the go. This cable is MFi certified for compatibility with Apple products.
Efficient syncing and charging
Designed to support both sync and charge functionalities, this cable ensures your devices are always ready to use. The seamless integration of Lightning and USB interfaces provides a hassle-free connection to a wide range of devices. -
Durable construction
Crafted with a PVC jacket material, the cable is built to withstand daily wear and tear, ensuring long-lasting performance. The nickel-plated connectors also offer a reliable connection, reducing the risk of corrosion over time. -
Universal compatibility
Featuring a male Apple Lightning connector on one end and a male 4-pin USB Type-A on the other, this cable is designed to connect seamlessly with a variety of devices, ensuring a versatile and practical charging solution for all your needs.
- C2G USB A Male to Lightning Male Sync and Charging Cable - Lightning cable - Lightning / USB - 1 m
- Cable
- Length
- 1 m
- Black
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- Limited lifetime warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Jacket Material
- PVC
- Impedance
- 100 Ohm
- Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- Black
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
- Limited warranty - lifetime
