Brand
C2G 1m USB 2.0 A Male to Micro-USB B Male Cable
Quicklinx: 801TWS00 Mfr#: 81700
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the on-the-go supplement.
C2G USB 2.0 A to Micro B Cable - USB cable - USB to Micro-USB Type B - 1 m
USB cable
Ferrite bead
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
USB cable
Ferrite bead
Length
1 m
Connector
USB / USB 2.0
