C2G 1m SC/SC LSZH Duplex 50/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6C1ZWS00 Mfr#: 85303
Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 50/125 multimode fibre, immune to electrical interference.
  • Enhanced safety
    The Low-Smoke Zero-Halogen (LSZH) jacket material ensures enhanced safety by reducing the amount of toxic and corrosive gas emitted during combustion. This makes the C2G Low-Smoke Zero-Halogen patch cable an ideal choice for environments where human and electronic safety is a priority.
  • High-quality connectivity
    Featuring a core and cladding diameter of 50 / 125 micron, this multimode fiber optic cable is designed for high-speed data transmission. The SC multi-mode connectors on both ends provide secure and reliable connectivity for your PC, ensuring optimal performance.
  • Robust compliance
    Adhering to RoHS compliant standards, the C2G Low-Smoke Zero-Halogen patch cable is manufactured with environmental responsibility in mind. This compliance ensures that the cable is free from certain hazardous materials, making it a safer choice for both users and the planet.
C2G Low-Smoke Zero-Halogen - patch cable - 1 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x SC multi-mode - male
Connector (Second End)
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
1 m
Orange
Connector
RoHS
