This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
                High compatibilityDesigned to connect seamlessly with PCs, this 1 m Mini DisplayPort Cable ensures a reliable connection between your computer and display devices.
                QualityCompliant with DisplayPort 1.2 standards, this cable supports 4K UHD video for visual clarity and an immersive viewing experience.
                Durable designFeaturing male connectors on both ends, this white DisplayPort cable is built for longevity and consistent performance, making it a reliable choice for daily use.
- C2G 1m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 1 m
- DisplayPort cable
- Length
- 1 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- White
- Limited lifetime warranty
- DisplayPort cable
- Length
- 1 m
- White
- Connector
- DisplayPort 1.2
