Parallel printer cables from C2G ensure a reliable connection between your PC and uni-directional printer. Parallel printer cables are ideal for dot-matrix and older laser printers. Don't be fooled by cheaply assembled look-alike cables - these cables are durable enough for use in industrial settings.
Robust connectivity
Experience seamless and reliable connectivity with the C2G printer cable, featuring a male 25 pin D-Sub (DB-25) connector on one end and a male 36 pin Centronics connector on the other. This design ensures a stable connection between your PC and printer, enhancing your productivity. -
Enhanced durability
Constructed with a foil shielding material, the C2G printer cable is designed to withstand interference, ensuring high-quality data transmission without loss or corruption. Its shielded technology guards against external noise, making it ideal for busy office environments.
- C2G printer cable - 1 m
- Printer cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 1 m
- Connector
- DB-25 - male
- Connector (Second End)
- 36 PIN Centronics - male
- RoHS
- Printer cable
- Technology
- Shielded
- Shielding Material
- Foil
- Length
- 1 m
- Connector
- 25 pin D-Sub (DB-25) - male
- RoHS
