C2G 1m Cat6 550 MHz Snagless Patch Cable - Red
Quicklinx: 6BQVWS00 Mfr#: 83446
Length: 1m
Colour: Red
£3.65 ex VAT
£4.38 inc VAT
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a secure, corrosion-resistant connection for uninterrupted network performance.
  • Enhanced performance
    Supporting tested frequencies up to 550 MHz, this patch cable is suitable for various networking environments. The T568B wiring scheme and CAT 6 category specification enable high-speed data transfer, making it suitable for applications requiring high performance.
  • Universal compatibility
    Designed to meet RoHS compliant standards, this network patch cable ensures compatibility with PC setups. Its universal design supports both high-speed Internet and intranet connections, facilitating seamless integration into existing network infrastructures.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
1 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 1m
Colour: Red
Brand: C2G
