For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, whether for home or office use. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for longevity. The gold-plated RJ-45 connectors provide a reliable connection, reducing the risk of corrosion and ensuring high-quality signal transmission. -
Universal compatibility
Featuring a T568B wiring scheme and male RJ-45 connectors on both ends, this cable is compatible with a wide range of devices. It's the perfect solution for connecting PCs and other network components in a seamless and efficient manner.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - purple
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Purple
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1 m
- Purple
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
