For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-speed connectivity
Experience fast data transfer speeds with the Cat6 Booted Unshielded (UTP) Network Patch Cable, tested up to 550 MHz to ensure rapid file transfers and smooth streaming. -
Durable design
Constructed with a high-quality PVC jacket and 24 AWG American Wire Gauge, this patch cable is designed for durability and long-lasting performance, making it a reliable choice for any network setup. -
Enhanced connection quality
Featuring gold-plated connectors, this network patch cable ensures optimal signal clarity and shielding against interference, providing a stable and secure connection for all your devices.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - grey
- Patch cable - CAT 6
- Technology
- Molded, snagless, stranded
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 550 MHz
