Make your work environment more flexible and efficient. This heavy duty 16 AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
Product Use
Extend the length of your power cord -
Warranty Details
This product carries a lifetime warranty -
Connector Information
- C2G 16 AWG 250 Volt 16 Amp Power Extension Cord - power extension cable - IEC 60320 C20 to IEC 60320 C19 - 1 m
- Power extension cable
- Molded
- Length
- 1 m
- Connector
- Power IEC 60320 C20
- Connector (Second End)
- Power IEC 60320 C19
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 16
- Rated Voltage
- AC 250 V
- Molded
- Length
- 1 m
- Black
- Connector
