C2G 15m Cat5E 350 MHz Snagless Patch Cable - White
Quicklinx: 6BN5WS00 Mfr#: 83268
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved signal integrity for your network. With a tested frequency of up to 350 MHz, this cable supports high-speed data transmission for a seamless networking experience
  • Durable design
    Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built to withstand rigorous use while ensuring optimal signal quality. The durable construction ensures a secure connection between devices, minimizing potential data loss
  • Universal compatibility
    Equipped with RJ-45 male connectors on both ends, this patch cable is compatible with a wide range of devices, including PCs. Its T568B wiring scheme and UTP technology make it versatile for various networking setups, ensuring easy integration into existing systems
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 15 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
15 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
