The SATA power adapter cable from C2G converts an existing 5.25 power connector into one Serial ATA power connector. Add, split, or extend your internal drive cables with an internal Serial ATA power cables.
- C2G Serial ATA (SATA) Power Adapter Cable - power adapter - 4 PIN internal power to SATA power - 15 cm
- Power adapter
- Length
- 15 cm
- Connector
- 4 PIN internal power - male
- Connector (Second End)
- 15 pin Serial ATA power - male
- Multicolour
- Limited lifetime warranty
- Power adapter
- Length
- 15 cm
- Multicolour
- Connector
- RoHS
