C2G 15cm Mobile Device USB Micro B to USB Device OTG Adapter Cab
Quicklinx: 9CRFWS00 Mfr#: 82410
The 15 cm Mobile Device USB Micro-B to USB Device OTG adapter cable is the perfect solution for expanding the capabilities of an OTG enabled tablet, smartphone or other mobile device by directly connecting a USB device such as a USB flash drive for additional storage or a USB keyboard and mouse for additional control. Connect a USB hub to this adapter to further expand the capabilities of the mobile device by connecting multiple USB devices. USB OTG technology makes this connection easy and does not require a driver, software or lengthy setup time. Simply connect the adapter to the Micro-B port on an OTG enabled mobile device, connect the USB device directly to the USB A port on the adapter and the two devices are ready to be used together.
  • Versatile connectivity
    Designed to bridge the gap between devices, this adapter cable effortlessly connects Android smartphones and tablets to a PC, enabling a seamless connection for data transfer and management.
  • High-quality construction
    Featuring a double-shielded structure with an American Wire Gauge (AWG) of 28, this cable ensures reliable performance and durability, minimizing interference and signal loss for superior data transmission.
C2G Mobile Device USB Micro-B to USB Device OTG Adapter Cable - USB adapter - USB to Micro-USB Type B - 15 cm
USB adapter
Double shielded
Length
15 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - female
USB adapter
Double shielded
28
Length
15 cm
Connector
