For RS-232 modular adapters for dumb terminal hookups and other serial/parallel extension applications. Constructed from 28 AWG silver satin wire, this straight through-pinned cable is ideal for cost-saving voice and data applications not requiring high data rates.
Reliable connectivity
The RJ11 6P4C Straight Modular Cable by C2G ensures a dependable connection between your PC and network devices. With male RJ-11 connectors on both ends, this phone cable is designed for straightforward, efficient connectivity. -
High-quality construction
Featuring an American Wire Gauge (AWG) of 28 and constructed with 4 wires per cable, this product promises durability and a high-quality signal transmission for your networking needs.
- C2G RJ11 6P4C Straight Modular Cable - phone cable - 10 m - grey
- Phone cable
- Wires per Cable
- 4 wires
- Length
- 10 m
- Connector
- RJ-11 - male
- Connector (Second End)
- RJ-11 - male
- Grey
- Limited lifetime warranty
- Network Cable Type
- Phone cable
- American Wire Gauge (AWG)
- 28
- Wires per Cable
- 4 wires
- Length
- 10 m
- Grey
- Connector
- RJ-11 - male
- RJ-11 - male
