C2G 10m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue
Quicklinx: 9N1JWS00 Mfr#: 89927
Length: 10m
Colour: Blue
£22.56 ex VAT
£27.07 inc VAT
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
  • Enhanced durability
    Featuring a PVC jacket and aluminum foil shielding, the Cat6a Booted Shielded (STP) Network Patch Cable is designed for superior protection against interference, ensuring a stable and secure connection.
  • High-quality connectivity
    With gold-plated connectors and American Wire Gauge (AWG) 26, this patch cable provides reliable, high-speed data transmission for demanding network applications.
  • Universal compatibility
    Designed to connect seamlessly with PC systems, the cable's RJ-45 male connectors on both ends ensure a perfect fit with a wide range of devices.
C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 10 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium foil
Wires per Cable
8 wires
Molded, snagless, stranded
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Aluminium foil
Jacket Material
PVC
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 94 V-0
Length: 10m
Colour: Blue
Brand: C2G
