For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transmission for your computing needs, making it an ideal choice for both home and office environments. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket material, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring your network setup remains uninterrupted. -
Universal compatibility
With its T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for connecting various devices. Whether you're setting up a new network or upgrading an existing one, the ease of connection and compatibility makes it a hassle-free choice.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - orange
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 10 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Orange
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 10 m
- Orange
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
