C2G 10m Cat6 550 MHz Snagless Patch Cable - Black
Quicklinx: 6BQBWS00 Mfr#: 83412
Length: 10m
Colour: Black
Hurry, only 2 left in stock!
£12.76 ex VAT
£15.31 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, offering tested frequencies up to 550 MHz for rapid data transfer.
  • Durable design
    Constructed with a PVC jacket material and 24 AWG American Wire Gauge, this patch cable is designed for durability and long-lasting performance.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and a T568B wiring scheme, this cable ensures compatibility with a wide range of devices, making it a versatile choice for various setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
10 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 10m
Colour: Black
Brand: C2G
