Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its gold-plated connectors and high-quality American Wire Gauge (AWG) 24 wiring. This combination provides a stable, high-speed link between devices. -
Enhanced performance
Designed to support frequencies up to 350 MHz, this patch cable facilitates high-speed data transmission and is ideal for a variety of networking applications. Its T568B wiring scheme and UTP technology help in reducing noise and crosstalk, enhancing your network's performance. -
Durable design
Featuring a PVC jacket, the cable is built to withstand rigorous or everyday use, ensuring longevity and durability. The robust construction also includes a male RJ-45 connector on each end, making it easy to connect devices. -
Universal compatibility
This network patch cable is compatible with PCs and supports a wide range of devices with an RJ-45 interface. Its universal design ensures it can be easily integrated into existing networks without compatibility issues.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 10 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 10 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
