C2G 1.5m Cat6 Snagless Cable Brown
Quicklinx: 6BVGWS00 Mfr#: 83646
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, offering tested frequencies up to 550 MHz for rapid data transfer.
  • Durable design
    Constructed with a PVC jacket material and 24 American Wire Gauge (AWG), this patch cable is designed for durability and long-lasting performance.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and a T568B wiring scheme, this cable ensures compatibility with a wide range of devices, making it a versatile choice for various setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - brown
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Brown
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
1.5 m
Brown
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
