This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
High-quality connectivity
Featuring a high-grade PVC jacket and 24 AWG construction, this Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable ensures durable and reliable connectivity for all your networking needs. The gold-plated connectors provide a secure connection and minimize interference, ensuring high-speed data transmission up to 350 MHz. -
Versatile network solution
Designed to support the needs of networking environments, this crossover cable facilitates direct device-to-device connections. With T568B wiring scheme and a configuration that supports up to 350 MHz for tested frequency, it's ideal for various PC compatibility scenarios, making it a versatile choice for both home and office networks.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 1.5 m - red
- Crossover cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 1.5 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 350 MHz
