C2G 1.5m Cat5E 350 MHz Assembled Patch Cable - Green
Quicklinx: 6BKQWS00 Mfr#: 83062
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality American Wire Gauge (AWG) 24 wiring and gold-plated connectors. Designed for durability and optimal signal integrity, this cable is perfect for both home and office networking needs.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this patch cable supports high-speed data transmission and has been engineered to reduce both impedance and structural return loss, resulting in faster and more reliable network connections.
  • Universal compatibility
    Featuring a T568B wiring scheme and RJ-45 connectors, this network cable is compatible with a wide range of devices and networks. Its universal design ensures it can be easily integrated into existing network setups without compatibility issues.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
1.5 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
