This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements.
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
                Enhanced durabilityThe Cat6a Booted Shielded (STP) Network Patch Cable is encased in a PVC jacket that offers robust protection against physical damage, ensuring long-lasting performance.
                Superior connectivityFeaturing gold-plated RJ-45 connectors, this cable provides a reliable, high-quality connection that minimizes the risk of data loss and enhances signal clarity.
                Advanced shieldingWith aluminum foil shielding, the cable effectively reduces electromagnetic interference, ensuring a stable and secure data transmission environment.
- C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 30 cm - grey
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Shielding Material
- Aluminium foil
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 30 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Limited lifetime warranty
- Network Cable Type
- Technology
- Aluminium foil
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 30 cm
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- UL 94 V-0
