C2G .5m 7-pin 180° to 90° 1-Device Serial ATA Cable
Quicklinx: 687FWS00 Mfr#: 81824
Serial ATA cables by C2G are designed to handle the differential signals implemented in today's technology. The angled connectors deliver the cable at a more desired angle and are fortified to keep the cable lined up straight. Serial ATA cables minimize clutter, increase airflow and provide maximum transfer rates. The 7-pin, Serial ATA cables permit higher data transmission rates, reduce crosstalk and improve signal integrity.
C2G 180 Degree to 90 Degree Right Angle Serial ATA (SATA) Cable - SATA cable - 50 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
90° connector, right-angled connector, 180° connector
Length
50 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
Storage Cable Type
SATA cable
Interface Speed
Length
50 cm
Red
Connector
