Buffalo Wireless N900 Gigabit Dual Band Router
Quicklinx: 9D4GWS00 Mfr#: WZR-900DHP-EU
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
Buffalo's new AirStation Dual Band Gigabit router (WZR-900DHP-EU) brings a new fast and versatile dual band solution to Buffalo's family of wireless routers. The WZR-900DHP-EU is primed and ready-to-go with simultaneous transfer speeds of up to 450MBps in both the 5GHz and 2.4GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance.
The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new AirStation's simultaneous fast transfer speeds in the 2.4GHz bandwidth.
The WZR-900DHP-EU also comes with USB 3.0 port, media server, device server, and BitTorrent for easy file sharing across connected devices. Additional advanced features such as QoS (Quality of Service) allow users to prioritize router traffic by type - the higher the priority, the higher the allocated bandwidth thereby helping ensure consistent performance across all your applications, and especially for your preferred applications.
Upgrade your existing wireless connection to provide greater coverage and fast transfer speeds: Buffalo's WZR-900DHP-EU is the next generation of wireless connectivity.
  • Dual band Gigabit router
    The WZR-900DHP is primed and ready-to-go with simultaneous transfer speeds of up to 450 MBps in both the 5 GHz and 2.4 GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance.
  • Gigabit speed
    With four gigabit LAN ports and one gigabit WAN the WZR-900DHP offers ultra-fast wired connections. Speeds can be up to 10x faster than standard Ethernet connection. Together with an USB 3.0 port it is extremely versatile.
  • Easy, secure setup
    The Buffalo AirStation One-Touch Secure System (AOSS), Wi-Fi Protected Setup (WPS) and the intuitive interface provide a quick and easy way to create a secure wireless connection to a host within minutes.
  • Easy file sharing
    The WZR-900DHP also comes with USB 3.0 port, media server, device server, and BitTorrent for easy file sharing across connected devices.
BUFFALO AirStation WZR-900DHP - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, IDS, MAC address filtering, VPN passthrough, parental control, AOSS, MIMO technology, QoS, WPS, port forwarding, BitTorrent Client, SPIF, DSSS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n, USB 3.0
2.8 cm x 18.5 cm x 20 cm
520 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Line Properties
Line Coding Format
OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
23 Watt
2.8 cm
18.5 cm
20 cm
520 g
10 - 85% (non-condensing)
9D4G C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
