Buffalo Terastation Pro II 1TB NAS
Customer rating: 3.0* (Write a review)
Quicklinx: 4J4GWS00 Mfr#: TS-H1.0TGL/R5-1
The TeraStation Pro II is the ideal choice for small to medium size businesses looking to implement a RAID based Network Attached Storage solution. Reliability and performance are the key design criteria for the TeraStation Pro II. Thanks to a clear LCD status display and an intuitive web interface the units are simple to install and manage.
BUFFALO TeraStation Pro II TS-H1.0TGL/R5 - NAS server - 1 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
1 TB
4 (installed) / 4 (max)
17 cm x 23.5 cm x 31 cm
7.3 kg ()
Europe
Storage Controller
RAID SATA 1.5Gb/s RAID 0, 1, 5, 10, JBOD
Hard Drive
4 x 250 GB SATA 1.5Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
AC 230V (50/60 Hz)
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP, Microsoft Windows Vista
NAS server
Host Connectivity
Gigabit Ethernet
1 TB
17 cm
23.5 cm
31 cm
7.3 kg ()
Built-in Devices
Status LCD
Europe
Storage Controller
RAID - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
HDD
4 x 250 GB
Interface Type
SATA 1.5Gb/s
Spindle Speed
7200 rpm
Network / Transport Protocol
TCP/IP, NTP, FTP, SMB
Remote Management Protocol
HTTP
Network Services Compatibility
Microsoft Active Directory (AD), DFS, FTP, Server Message Block (SMB), HTTP
LDAP support, DFS support, Jumbo Frames support, FTP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Bays
4 (total) / 0 (free) x external
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
Internal power supply
AC 230V (50/60 Hz)
60 Watt
Software Included
Memeo AutoBackup
35 °C
Customer reviews
Write a review for the Buffalo Terastation Pro II 1TB NAS here!
Quick and painless network storage.
Reviewed by Neil. Review Posted 06/06/2007
Extremely quit in operation, and came configured for RAID5. Hardware and software installed first time, and the system has performed reliably. If you want to use the TeraStation from more than one computer.Go to the 'Memeo' website and buy online the latest version (it is only around £10 a copy) and has many more features. The Memeo software was the best £10 I have ever spent.. You will not be dissapointed by the drive or software.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Quick, easy and good value
Reviewed by Nick. Review Posted 13/08/2007
Quick and simple to set up, small, quiet and unobtrusive. The best feature is its Active Directory/Windows Domain support. This means business users can plug it into their network, connect it to their domain and let Windows take care of user authentication, permissions, etc.
  • Overall 5*
  • Ease of use 5*
Reviewed by Steve. Review Posted 02/11/2007
Set as Raid 5 this NAS is slower than the 250Gb external USB HDD which it was to replace. It takes 3 times longer to backup my main drive than the USB disk!!! Not impressed and have since found similar reviews.
Used just as NAS then its ok.
Disappointed.
  • Overall 3*
  • Ease of use 5*
  • Value for money 2*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
