DriveStation Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 rpm drive. If you haven't moved up to USB 3.0 yet - DriveStation Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
SuperSpeed USB 3.0
The USB 3.0 interface is ideal for video and other data intensive digital content. -
TurboPC EX utility
TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility. Saving, copying, and transferring files is even faster. -
High speed 7,200 rpm hard disk
The disk reads and writes data faster, so you spend less time waiting when transferring and saving files. -
Hardware disk encryption
256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access on PCs. -
Back up your files
Buffalo's backup utility automatically backs up your Windows PC, protecting your data. -
RAMDISK virtual disk utility
The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory). -
SuperEco
It saves power consumption during stand-by mode by auto power off. -
Plug and Play connectivity
Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings. -
Fully backwards compatible with USB 2.0
No adjustments are needed, just plug into any USB 2.0 port.
- BUFFALO DriveStation Velocity - hard drive - 6 TB - USB 3.0
- Hard drive - external (desktop) - Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support
- Capacity
- 6 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 7200 rpm
- Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support, 256-bit AES
- 3.9 cm x 18.9 cm x 12.3 cm
- 950 g
- Localisation
- Europe
- 2-year warranty
- Capacity
- 6 TB
- Interface
- USB 3.0
- 3.9 cm
- 18.9 cm
- 12.3 cm
- 950 g
Performance
- Interface Transfer Rate
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type B
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption
- 18 Watt (active) , 150 mW (standby)
- Software Included
- Buffalo Tools
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Plug and Play
- Localisation
- Europe
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
