MiniStation Plus offers high performance USB 3.0 portable storage in a compact and lightweight shock proof chassis. With USB 3.0 support and backward compatibility with USB 2.0, it works with any PC or Mac, providing interface speeds up to 5 Gbps. MiniStation Plus occupies minimal space and it's USB powered so there are no additional cables to manage and no need for a separate power source; simply plug it into any available USB port on your computer and instantly add capacity or store files to take on the road. With available 256-bit AES hardware encryption, you can easily protect your data from unwanted access by simply assigning a password. Store, back up and transport your content with SuperSpeed plug and play connectivity.
Compact and convenient
Designed for mobility, MiniStation Plus's compact and contemporary design occupies minimal space and offers USB powered mobile storage for your data and for your on-the-go lifestyle. Plus, the Plus works with PC and Mac so you can access your files from whichever computer you are on. -
Shock proof chassis
Shock protection elements surround the hard drive, protecting it from accidental bumps and drops. Transport your content without worry of damage. Shock protection elements help protect the hard drive from accidental bumps and drops. -
USB 2.0 compatibility
MiniStation Plus is fully backward compatible with USB 2.0 enabled desktop computers and notebooks. Simply plug the cable into the USB 2.0 port and you are connected - no additional hardware or cables are required. -
Compact and lightweight
Super slim, lightweight chassis saves space for ultimate portability with a stylish, sophisticated design. -
USB powered
It's perfect companion for your laptop or netbook - no external power supply needed. -
SuperSpeed USB 3.0 with TurboPC
Utilizing the high speed RAM of your Windows PC, TurboPC can increase file transfer rates by up to 3x over competing USB 2.0 portable hard drives. TurboPC also includes TurboCopy which draws on additional system adjustments to increase performance substantially. -
Eco manager
Eco minded power management tool regulates power usage, conserving energy and battery consumption.
- BUFFALO MiniStation Plus - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- Enclosure Colour
- Silver
- 8.2 cm x 1.6 cm x 11.8 cm
- 175 g
- 2-year warranty
- Capacity
- 500 GB
- Interface
- USB 3.0
- 8.2 cm
- 1.6 cm
- 11.8 cm
- 175 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Power Consumption
- 2.7 Watt (active)
- Software Included
- Buffalo Tools
- OS Required
- Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- Enclosure Colour
- Silver
- Limited warranty - 2 years
